Here we go..
Electric dryer just quit working. Power to dryer is fine but all I get is a "click", like a circuit opening, at the circuit board.
Replaced board with genuine OEM part and I figured while I was at it I'd replace the thermister and thermal fuse with new ones.
Plugged it back in....same thing.
Just a click like a circuit is opening.
Any suggestions except the trash heap.
Groups: Expert
This dryer has belt switch, so if the belt broke or came off, the dryer wouldn't run.
