Prowler7272
#1 Posted : Sunday, February 18, 2018 3:39:15 PM(UTC)
Prowler7272
So I watched all the videos and tested all the parts it said to check and everything tested good. My ignitor glow stick still won’t glow. Any help appreciated.
cbmserviceguy
#2 Posted : Friday, February 23, 2018 8:45:10 AM(UTC)
cbmserviceguy
Not sure what all you tested, but it's probably a pretty basic problem. If you unplug the ignitor and test the ohms, what do you get? Also, how many volts is the dryer supplying to the ignitor when it tries to run?
Prowler7272
#3 Posted : Friday, February 23, 2018 4:26:11 PM(UTC)
Prowler7272
I get 122.8 ohms on the ignitor and no voltage when I tested the lead to the ignitor when I turned in the dryer.
cbmserviceguy
#4 Posted : Monday, February 26, 2018 7:32:55 AM(UTC)
cbmserviceguy
You probably had a bad limit or t-stat. Do you have have the model number? Going to have to look at a wiring diagram and work backwards til you find where you are losing voltage.
Prowler7272
#5 Posted : Tuesday, February 27, 2018 7:32:32 AM(UTC)
Prowler7272
Was a bad timer. I took it apart and cleaned the contacts and is now working. Thank you for your help.
Guest (4)
