mooreg1
#1 Posted : Tuesday, February 6, 2018 7:59:24 AM(UTC)
mooreg1
Maytag Double Oven, Model MER6757BAS. I had to replace the broiler element in the upper oven. No problem easy as pie. Well the oven only heats and bakes using the lower element. Broiler element will not even get warm. Cold!! Set to broil, will not come on. Set to clean mode, nothing comes on in the upper oven. Checked wires and do not see any breaks in the wiring leading back to the control panel.
