Amana microwave model # RR 810 Mfg # P75592 2M Sometimes it will blow the fuse when you open the door. Might work fine 20 times, then it will blow it the next time. Or might use it twice and then blow it again. Where do I start looking to fix this? Don't like new microwaves. This old one works better if I can keep it from blowing the fuse. Thanks.
Groups: Expert
Thank you! I will give that a try!
