I have a GE Profile oven (pgs975sep2ss) that worked fine yesterday, and today it will not turn on the bottom burner (Bake function). Broil or convection (any function that turns on the top burner), will begin to heat up the oven, but only with the top burner. The lower burner at the bottom of the oven will not lite.:confused: Please advise on how to test for part to replace.
Groups: Expert
Thanks ThatGuy. I finally got around to taking it apart, and I think you might be right. When I turn on the oven, the plug does not glow. It doesn’t feel hot and other. I then disconnected the plug at the harness and put a voltmeter on it. When I turn on the oven, it reads current, and then drops when I turn it off. Seems like your Assessment was spot on. Thanks!
