AppliancePartsPros.com
Appliance Repair Help
Washer Repair
LAT2500AAE will spin,rinse,and drain but won't agitate
My LAT2500AAE will spin,rinse,and drain but won't agitate. It spins counter clockwise , but it won't agitate. The agitater isn't stripped. Please help. It would be appreciated. Thank You, J
Groups: Expert
Does it do anything when its supposed to be agitating? Motor hum? Grinding noise?
Thank You for replying to my question. I think is sounds more like a humming noise. My motor spins. Do you know why it wouldn't be agitating? MDo you know what exactly I would need to buy to fix it? Thank You, J
Groups: Expert
Tip the washer back and take both belts off .
You should be able to rotate the center pulley one way and it will spin. Rotate it the other way and it should agitate.
If instead it does nothing or locks up, the transmission is bad.
Groups: Expert
I can rotate it counter clockwise, but I cannot rotate it clockwise. I have seen all the washers currently being sold. I really just want to fix my washer. Would you please tell me what I would need to buy to fix it? Thank You, J
I can get a transmission for $ 100.00 but I still need to know what else I will need to replace on my washer to fix it. Thank You, J
I am assuming I will need to replace the tub bearing kit and the Mounting Stem Repair Kit. They are in stock, but I don't want to buy any parts I don't need, and I wanna buy only the parts I need to make it work again. I already bought new springs, glides for the motor, and new belts from appliance parts pros,but replacing those didn't help. Now I know why since my transmission needs replaced. So I need to know what else I need to buy to get it working again, please. Thank You, J.
Groups: Expert
Thank You, ThatGuy. I agree. I am purchasing the spanner wrench first, so I can see how rusty the tub might be. I will let you know what I find. Thank You, J
Washer Repair
