srivatsa11
#1 Posted : Thursday, January 11, 2018 6:16:18 PM(UTC)
srivatsa11
Can you tell me how to remove the Drum Lifter from the drum and replace a new one? The lifter part number is DC66-00508A. Thank you so much in advance.
ThatGuy
#2 Posted : Sunday, January 14, 2018 1:33:48 AM(UTC)
ThatGuy
Groups: Expert
United States
Looking at the part, it looks like you remove a screw from the outside of the drum and then it slides to the side and comes off.
ThatGuy attached the following image(s):
srivatsa11
#3 Posted : Monday, January 15, 2018 10:19:22 AM(UTC)
srivatsa11
Thank you ThatGuy sir for your advise. Would you know if I can access the screw without removing the drum or the drum needs to be pulled out? Many thanks for your prompt response on this.
regards,
Guest
#4 Posted : Tuesday, August 29, 2023 8:32:01 AM(UTC)
Guest
Rank: Guest
Groups: Guests
United States
front half of outer tub has to be removed
