SamWasher
#1 Posted : Monday, December 4, 2017 7:30:09 AM(UTC)
SamWasher
Our Samsung front-loading washer has started spitting out dark gray grit from the discharge hose. The filter by the pump has caught a few chunks about half inch across. The material is hard as rock and is not attracted to a magnet. The drum seems to wobble. The pump is draining fine. Any ideas?
SamWasher
#2 Posted : Tuesday, January 9, 2018 1:17:21 PM(UTC)
SamWasher
Had a service person come out. Despite being only seven years old the Samsung washer is now just junk. Repair cost is over $800 just for parts. Apparently the mounting brackets for the drum are completely corroded and disintegrating.
