maytagNewbie
#1 Posted : Thursday, December 14, 2017 7:14:00 AM(UTC)
maytagNewbie
Maytag centennial dryer is making loud banging noise while drying. What could be the problem? I can attach a video of the problem if needed.
Thanks.
ThatGuy
#2 Posted : Thursday, December 14, 2017 1:23:53 PM(UTC)
ThatGuy
Groups: Expert
United States
A model number and a video would help .
maytagNewbie
#3 Posted : Thursday, December 14, 2017 3:19:15 PM(UTC)
maytagNewbie
How do I find the model number? Until I can find the model number I have a link to a picture of the dryer: https://imgur.com/a/yJ3GX
How do I attach video? Should I zip the video file and upload it?
Thanks.
#4 Posted : Thursday, December 14, 2017 7:13:24 PM(UTC)
You can find the model and serial number label on the door frame.
ThatGuy
#5 Posted : Friday, December 15, 2017 7:47:21 AM(UTC)
ThatGuy
Groups: Expert
United States
I upload videos to YouTube or a service like Photo Bucket and then post a link.
maytagNewbie
#6 Posted : Friday, December 15, 2017 3:08:16 PM(UTC)
maytagNewbie
The model number is MEDC215EW0
I will upload a video and post a link.
maytagNewbie
#7 Posted : Friday, December 15, 2017 6:17:19 PM(UTC)
maytagNewbie
Here is a link to a sound recording.
https://vocaroo.com/i/s0kDOHr7RP7J
Thanks.
#8 Posted : Saturday, December 16, 2017 11:36:12 PM(UTC)
Remove the front panel and drum as described in the attached instructions.
Inspect the front bearings and rear drum support rollers. Any worn out parts would need to be replaced.
You can find the correct part numbers in the following diagrams. Let us know if you'll need to locate correct part numbers.
Here are the diagrams for the Maytag dryer Model MEDC215EW0
File Attachment(s):
thorning
#9 Posted : Monday, December 18, 2017 6:22:15 AM(UTC)
thorning
Also check the drum to make sure there is no part of it that is damaged where it contacts the rollers/bearings.
maytagNewbie
#10 Posted : Thursday, December 21, 2017 3:15:27 PM(UTC)
maytagNewbie
Thanks, will try these suggestions tomorrow or the day after and see if it works. :)
