Rank:: Member
Hello, first time poster. I thought I would hijack this thread since it didn't go on any more and I could use the pictures that are on it.
I have same oven and the pictures are already on here so I thought I would ask a question about this range.
My bake element works intermentitly.....the broil element works, the convection fan works, the broil fan works. the problem is that the bake element will not come on for awhile, but then it will come on and glow red, so I assume the bake element is ok.....could this be a bad hot wire relay part number WB21X5362
Or maybe an oven temp sensor?
I have made sure the high temp cut out button is pushed in.
any help would be great.
I also switched the relays between the bake and broil, but no luck.
Thanks in advance
Dan
Originally Posted by: mobial  Hi - I added some more info about my problem in this post. Were you able to fix thia problem? I have the same issue with a similar model.
Rank:: Member
Yes. Mine turned out to be the hot wire relay like what's in the picture in the other posts. Works perfect since the repair
