My washer is leaking from the seal under the tub. I purchased the kit # w10116791. I've got as far as removing the inner tub bolts but tub will not come out. So I've removed the whole tub assembly from the washer. I'm going to try and soak the area with penetrating oil and see if that helps. I've looked all over internet for video but no luck.
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Thanks for your help but the video of the washer was totally different from what I have. I thought I read some where's a guy left a link to how to get a stuck inner drum apart? I have soaked mine over night and I still can not break it loose.
