During troubleshooting, the harness fuse on our GE washer tested open. I jumped it, and agitation and spin both work - motor seems fine. According to the manual the fuse is a 10 amp non-resettable, part number WH49X10041 which was replaced by WH49X10055.
Can't find a WH49X10055. Anybody know of a serviceable substitute for WH49X10055, a 10-amp fusible link?
Thank you and cheers.
Groups: Expert
Check $ears under part number WH49X10041
Thanks, I will check that out.
