johna56
#1 Posted : Thursday, November 2, 2017 1:49:28 PM(UTC)
johna56
Views messages in topic : 8
The dryer started making a noise which sounds like a very loud rubbing of vibration noise that is relatively consistent when the dryer is in use. I've pulled it apart and the blower fan, tension wheel and motor appear to be solid - no looseness or squeaks when i turn them, or push/pull them. While looking at the rear bearing on the drum, it appear that the bearing (ball) attached to the drum has some grooves in the side, and the plastic seat that is attached to the rear wall also appears to have some grooves in it. I feel pretty comfortable that the likely culprit of the noise is just vibration from the seat and bearing having grooves. Am i completely wrong here, is there anything else I should should look at and do these need to be replaced or are grooves typical and i just need to add new grease? It was pretty dry and Im not sure what type of grease, although I read lithium grease is the type I should use.
Thanks for reading and responding (if you respond).
-j
johna56
#2 Posted : Friday, November 3, 2017 6:32:53 AM(UTC)
johna56
is there insufficient info to go on here?
johna56
#3 Posted : Friday, November 3, 2017 6:34:15 AM(UTC)
johna56
**deleted**
thorning
#4 Posted : Friday, November 3, 2017 6:57:15 AM(UTC)
thorning
If the bearing parts have grooves in them they are worn quite a bit and should be replaced. Use Hi temp lithium grease when putting the new parts into the dryer. Use this grease sparingly however.
johna56
#5 Posted : Friday, November 3, 2017 8:59:36 AM(UTC)
johna56
Thank you.
ThatGuy
#6 Posted : Friday, November 3, 2017 4:14:23 PM(UTC)
ThatGuy
Groups: Expert
United States
The ball on the rear of the drum should be smooth. The grease usually comes in the kit.
Parts for Kenmore Dryer 41774182300 - AppliancePartsPros.com
UserPostedImage
johna56
#7 Posted : Friday, November 3, 2017 6:30:20 PM(UTC)
johna56
Awesome. Thank you.
Samsung dryer noise (Dryer Repair)
by Guest 5/31/2021 10:07:46 AM(UTC)
Maytag dryer noise (Dryer Repair)
by Cmjb13 9/7/2017 7:20:37 PM(UTC)
by hitmehhh 10/7/2016 5:35:15 AM(UTC)
Plz help. affinity dryer noise. (Dryer Repair)
by JHX 4/8/2016 11:42:59 AM(UTC)
by hitmehhh 11/20/2015 5:07:53 AM(UTC)
Maytag Dryer Noise (Dryer Repair)
by azure012 7/11/2014 6:41:40 AM(UTC)
Dryer noise (Dryer Repair)
by jayjay19 1/3/2012 11:15:39 AM(UTC)
by hoan 12/30/2011 1:19:14 PM(UTC)
by Dan2175 12/21/2011 6:30:18 PM(UTC)
by wesw 11/5/2011 6:49:55 AM(UTC)
Elec Dryer Noise (Dryer Repair)
by mstickma 7/11/2011 9:12:54 AM(UTC)
by lmckelvy 11/9/2010 1:19:54 PM(UTC)
Frigidaire Gallery Dryer Noise (Dryer Repair)
by c24miller 10/15/2010 11:50:54 AM(UTC)
kenmore dryer noise (Dryer Repair)
by nobel5601 9/22/2010 1:34:49 PM(UTC)
by reecemj 5/31/2010 6:29:09 PM(UTC)
