danr407g
#1 Posted : Friday, November 3, 2017 4:17:41 PM(UTC)
danr407g
my maytag gas range oven/broiler was intermittent and now stopped working completely. The gas range top works fine, but the oven and broiler do not work, when I press bake/start, I hear a click and then nothing. I ran the diagnostic mode and there are no error codes. I measured the voltage from J1-4 to J1-6 in bake mode and the reading is 126 volts ac. I measured the voltage from J1-4 to J1-7 in broil mode and the voltage is 126 volts ac. Also the voltage to the DSI board J1-4 to J1-10 is 126 volts ac. The resistance between the bake valve j1-1 and j1-2 is 216 ohms, and the resistance between the broil valve j1-2 and j1-3 is 216 ohms. I replaced the DSI board and still get the same results, the oven and broiler do not light. Any help would be appreciated.
