Hello Pro's
My Maytag is squeaking only when it brakes. Can you identify the parts required for this and ease of repair? I believe I did a similar repair years ago on a similar washer and it was quite involved, although I cannot recall for sure. Any help is appreciated....!
Groups: Expert
It might be the brake rotor and if it is, its rather "involved" as you say. Here is a video on changing the snubber. You can see part of the brake rotor and it is a little harder to change. You have to remove that pulley and the cover underneath. Its a big job. Washer Snubber Ring (part #WP21002026) - How To Replace
Thanks a bunch....the video does bring back some memories...
