2 Pages12>
hokiehivpi
#1 Posted : Wednesday, October 25, 2017 6:49:53 AM(UTC)
hokiehivpi
Hello, I bought a supposed working ice machine recently only to find out it wasn't working. I now have hopes of bringing her back to life.
Using the diagnostic mode, I can tell that everything works except for the recirculation pump and the drain pump. Water valve opens, reservoir fills, plate chills, compressor, everything works except the circulation pump and the drain pump. I pulled the control board down and reseated all the harness plugs back onto the board to no avail.
Is there anything else I should be checking before ordering a new controller board?
Thanks in advance!
ThatGuy
#2 Posted : Wednesday, October 25, 2017 6:58:02 PM(UTC)
ThatGuy
Groups: Expert
United States
Have you checked for voltage to the pump? Does the pump ever run?
hokiehivpi
#3 Posted : Thursday, October 26, 2017 3:45:49 AM(UTC)
hokiehivpi
Thanks I did check for voltage at both the recirculation as well as the drain pump while running through the diagnostic cycle and the highest I ever got was 1V, so I'm just a mere 109V away, ha!
It was after I did the voltage check that I pulled the controller card down and reseated all the plugs on it (to no avail). I have a card on order now and I'm hoping that's the solution. If there's anything else I can be checking in the meantime, please let me know. Thanks!
ThatGuy
#4 Posted : Thursday, October 26, 2017 11:38:32 AM(UTC)
ThatGuy
Groups: Expert
United States
According to the back of the one pump, it takes 12 volts, 60 Hz, 1.2 amps to run it.
ThatGuy attached the following image(s):
ThatGuy
#5 Posted : Thursday, October 26, 2017 11:48:52 AM(UTC)
ThatGuy
Groups: Expert
United States
I'd check the transformer and see if its outputting the correct voltages. If it is, then its probably the board.
Whirlpool WP2310139 Transformr - AppliancePartsPros.com
hokiehivpi
#6 Posted : Thursday, October 26, 2017 12:13:06 PM(UTC)
hokiehivpi
Thanks so much! I'll go check that here in a bit and see. Interesting that the drain pump is 12V. From everything I've seen online, the recirculation pump is 110.
hokiehivpi
#7 Posted : Friday, November 3, 2017 6:06:49 AM(UTC)
hokiehivpi
Ok, so I got the new board in, slapped it in and it still doesn't work. I checked voltages at the harness in the ice box again and got nothing. How can I test the transformer since it has one plug? Also wouldn't the transformer also supply the same 12V to the light that's working fine?
Thanks in advance.
ThatGuy
#8 Posted : Friday, November 3, 2017 4:04:09 PM(UTC)
ThatGuy
Groups: Expert
United States
A wiring diagram would be nice. Couldn't find one. I did find a picture of the label on the transformer and I enlarged it.
It looks like black and white are 120 VAC.
Yellow is 5.4 volts AC
And red is 12.8 volts AC
Always check your voltages first. Less guessing, more testing.
hokiehivpi
#9 Posted : Friday, November 3, 2017 5:10:58 PM(UTC)
hokiehivpi
Ok so tomorrow I'll cut the wires and see what she's putting out. Thanks again for the assistance!
ThatGuy
#10 Posted : Saturday, November 4, 2017 4:21:53 PM(UTC)
ThatGuy
Groups: Expert
United States
Don't cut the wires!
Stick your test meter's probes in the back of the connector. Get your voltage readings there. Like this pic shows.
UserPostedImage
Guest (4)
2 Pages12>
