dblaxxion
#1 Posted : Monday, October 16, 2017 12:04:00 PM(UTC)
dblaxxion
New guy here, and hope it's ok to post this question here:
I'm looking for a potentiometer for a left side burner for the subject model. I'm told it is no longer available. The oven has seen little use and looks like new so I would like to find a part that works, whether new or used.
The part number I have is 00497235, which is a kit, but all I really need is a replacement potentiometer. Can anyone suggest where I might find one.
All help is greatly appreciated.
clarkx
#2 Posted : Thursday, October 4, 2018 2:02:20 PM(UTC)
clarkx
I've posted a few versions of this info on the forum because I was beating my head against the wall for a couple days on this and wanted to save you the headache. By the way the kit is no longer available either. There are solutions for the (Simmer Control Module) as well; see: http://forum.appliancepartspros...lo-issue.html#post916616
Symptom, no gas was coming out of one of the XLO burners (no relay click and no gas sound when you turn on the burner). Check the voltage to the relay, common problem). Again no part available, I had to pull the pot apart and fix an open connection on the pot board. Use an ohm meter to check resistance from the connector closest to the edge of the pot pcb (should read no resistance). The pot wiper arm cuts the pcb trace over time. You can use this conductive paint to repair the pot board. MG Chemicals 842AR-P Silver Conductive Pen. If over time it happens again I plan to drill an couple holes in the board and use pen to put a trace on the other side where it wont be affected by the wiper.
