Liddell
#1 Posted : Monday, May 25, 2009 6:14:11 AM(UTC)
Liddell
My freezer runs but the temp light came on and it is not as cold. The vaccume, or woosh sound I used to hear when I closed the door is not there. The gasket around the door looks ok. Is it time for a new freezer or is this something that is worth fixing?
#2 Posted : Monday, May 25, 2009 5:31:30 PM(UTC)
Replacement parts for FRIGIDAIRE FFU20F9GW0 | AppliancePartsPros.com
Is the fan in the freezer working?
Also remove the Evaporator coil cover and see it the coils are fairly clear of ice.
If heavily iced/frosted up you may have a defrost problem.
