hinspect
#1 Posted : Saturday, September 16, 2017 12:14:28 PM(UTC)
hinspect
I have Amana bottom freezer refrigerator model #BX22S5L (P1196701WL) I need instructions on how to remove the drip tray to clean
PNWDrew
#2 Posted : Sunday, September 17, 2017 12:31:12 PM(UTC)
PNWDrew
That really isn't an option on that unit. It's possible but not something that a DIYer really would tackle.
Why do you want it cleaned?
hinspect
#3 Posted : Sunday, September 17, 2017 1:20:10 PM(UTC)
hinspect
It has old standing water and stinks worse than a mildewed rag!
PNWDrew
#4 Posted : Sunday, September 17, 2017 1:51:26 PM(UTC)
PNWDrew
Ah... Each defrost will drop a cup or more of water in there. It should dry by evaporation. If it isn't drying it can get nasty. If there isn't much airflow due to clearances around the unit that can hinder drying too.
Check that the grille in front is clear and the condenser is clear. The fan will usually move enough air through to dry the pan in between defrosts.
Beyond that you can carefully access from back and clean the pan. Unplug it so the fan doesn't bite you.
How do I remove drip tray (Refrigerator & Freezer Repair)
by emock1 2/21/2012 12:04:56 PM(UTC)
