gesche444
#1 Posted : Friday, September 15, 2017 12:21:36 PM(UTC)
gesche444
How do you check these parts?
Temp. Sensor - part AP6021414
Paul
Received this email from Appliance Parts & Pros;
Paul Gesche 5:52 PM (22 hours ago)
We noticed our lower oven bake element was not working. Went online to you an...
AppliancePartsPros.com Customer Service (sent by mandiet@appliancepartspros.com)
7:48 AM (8 hours ago)
to me
Hi Paul,
This is Mandie with AppliancePartsPros.com. If both elements are out the first thing I would suggest to check is your temperature sensor, part AP6015486, Whirlpool WPW10131825 Oven Sensor - AppliancePartsPros.com. [COLOR="Red"]If that tests okay[/COLOR], you may have an issue with your main control board, part AP6021414 Whirlpool WPW10438751 Electronic Control Board - AppliancePartsPros.com. Also, check wiring and connections from the board to the oven, for any loose or burn out wires. I hope this helps, if you need anything else, please let us know.
If you have any questions, please reply to this email or call us at the number below.
Sincerely,
​Mandie
Customer Service
AppliancePartsPros.com team
Phone: 1-877-477-7278 ex ​​3044​
Online: Appliance Parts Pros.com Discount Appliance Parts
Free Repair Help: Appliance Repair Forum - Free Service from Appliance Parts Pros
Business Hours:
7am - Midnight (Eastern Time) / 7 days per week
gesche444
#2 Posted : Saturday, September 16, 2017 10:27:24 AM(UTC)
gesche444
Have the sensor out of the lower oven. Cannot find a place to read continuity. The two wires are insulated. The connector holes are to small to put the probes in. The only two things I can think of is 1. rub away the wire insulation. 2. put wires on the connector holes and measure resistance from them. What do you think?
gesche444
#3 Posted : Saturday, September 16, 2017 2:31:51 PM(UTC)
gesche444
Was able to read continuity. It reads 1100. I understand the reading should be 1180 - 1190. Does that mean this sensor is bad?
