Samsung bottom freezer draw is frosting over now for about 2 weeks. getting heavier in frost. two model numbers on nameplate RF266AERS & RF266AERS/XAA.
need help to solve the frost problem.
well with no luck on answers. I pulled the inside back wall off and puled the defrost element out. check for continuity. there was none. bought the part off here. installed and works like a charm. no frost.
