Peb
PEB1950
#1 Posted : Monday, July 31, 2017 12:26:36 PM(UTC)
PEB1950
low temp not working. high temp heats normally
PNWDrew
#2 Posted : Monday, July 31, 2017 10:24:22 PM(UTC)
PNWDrew
Not working as in no heat at all when a low temp cycle is ran?
PEB1950
#3 Posted : Tuesday, August 1, 2017 3:32:30 AM(UTC)
PEB1950
no heat at all when low cycle is run
PEB1950
#4 Posted : Tuesday, August 1, 2017 3:36:10 AM(UTC)
PEB1950
I'm going to test high limit thermostat and the low temp switch for continuity first
PNWDrew
#5 Posted : Tuesday, August 1, 2017 6:23:09 AM(UTC)
PNWDrew
If your hi limit was open it wouldn't heat at all. No harm in testing it of course, But the temp switch is a likely suspect.
GE Microwave Louder and Not Heating PEB7226SF2SS (Microwave Repair)
by Guest 7/24/2022 9:39:41 AM(UTC)
GE Model PEB1590SM2SS (Microwave Repair)
by joeybike 3/7/2022 5:26:45 PM(UTC)
