memyer
#1 Posted : Tuesday, December 18, 2007 7:39:00 PM(UTC)
memyer
Will not cycle except on rinse/hold. It will reach a point after filling when it just keeps running at that spot, e.g., will run at 84 minutes forever. I have to let it run for a while, then drain, then run the rinse/hold cycle to get the dishes clean.
memyer
#2 Posted : Tuesday, December 18, 2007 7:44:49 PM(UTC)
memyer
The machine will not cycle in either the regular or delicate cycle, but will for the rinse/hold cycle. It will fill up and run to a time point on the display, e.g., 84 minutes, and keep running at that display time forever. The only way I can get my dishes clean is to let it run for a half hour or so, then cancel/drain, then run the rinse/hold cycle and let air dry.
kawfeeman
#3 Posted : Wednesday, December 19, 2007 4:31:00 AM(UTC)
kawfeeman
replace control module part # 266746... ( more than likely heater is not being activated... ) if you are so inclined you can remove the control module from the control panel and open it up and check and see that there will be a burn mark on one of the relays on the pc side of the board.. )
Bosch sprayer channel clip spot weld failed on back wall (Dishwasher Repair)
by Billymons 6/15/2024 5:23:17 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Bosch Ice Maker Dropping Ice Once Week (Refrigerator & Freezer Repair)
by Guest 5/31/2024 1:40:51 PM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
Replacing a stacking Bosch Axxis+ Washer (Washer Repair)
by DonLafontaine 3/22/2024 3:59:06 AM(UTC)
Bosch SHP88PW55N water softener issue / replacement (Dishwasher Repair)
by jgoode0417 3/13/2024 8:03:16 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
EA120 EA150 Bosch Error Code - Built In Refrigerator (Refrigerator & Freezer Repair)
by Peter Franks 2/13/2024 4:55:41 PM(UTC)
Blows fuse when door is closed (Bosch HMC80251UC) (Microwave Repair)
by mana 1/13/2024 6:06:57 PM(UTC)
Bosch dishwasher troubleshooting (Dishwasher Repair)
by Dan T in SD 12/7/2023 2:38:23 PM(UTC)
Need help to find pump for bosch wfmc4300uc/01 (Washer Repair)
by revox 11/25/2023 8:26:21 AM(UTC)
Bosch ventless dryer sump pump not working (Dryer Repair)
by mdavidson 11/18/2023 2:22:57 AM(UTC)
Bosch Dishwasher intermittently leaking on lower right of door (Dishwasher Repair)
by jjtrinva 11/5/2023 9:30:06 AM(UTC)
