Dumb a** here, I forgot to note wire/terminals configuration. Can someone with same unit send a photo or sketch of connected part? Wires needed to reconnect: 2x red (ganged) 2x orange (ganged) 1x blue See photo attached. Many thanks in advance Btw: I have worked on this unit extensively over the years. Within days of installing unit I noticed one door hinge was not configured correctly. I figured that one out. Best bet-two person job. One to pull door, one to attach hinge correctly. Within two years both left side burners were not working. By the time I got around to looking at them the parts were unavailable or very expensive. Would have had to replace both potentiometer and spark control unit. I ended up finding manual valves (for left side) and disconnecting spark control unit. Works great as manual stove top. Bonus: works when power goes out. I'm trying to figure out a way to hook up a push button on/off for spark. acblaisdell attached the following image(s):
