mbrittb00
#1 Posted : Wednesday, July 19, 2017 5:00:50 AM(UTC)
mbrittb00
I've got a Whirlpool Dishwasher, WDF510PAYSA, whos sanitized light has recently started blinking at the end of the cycle. I have already tested and replaced the heating element (which was bad), but the issues still exists. I think my next step is to test the thermostat. I'm looking for a closed circuit at room temperature and an open circuit at high temperature, correct.
Also, I only see one thermostat for this dishwasher not a separate thermostat and high-limit thermostats. Is this correct.
Thanks,
mbrittb00
#2 Posted : Wednesday, July 19, 2017 4:04:00 PM(UTC)
mbrittb00
Tested out the thermostat this afternoon. At room temp it read 0.6 Ohms. Not sure what to try next. Showers seem to have plenty of hot water, so I don't think that is it. Maybe one of the hot water elements is going bad and we are running out of hot water before the dishwasher finishes (Cycle takes about 2 hours)
Any other suggestions would be appreciated.
