john437
#1 Posted : 16 years ago
john437
ive run the dryer thru every cycle,everything works, except it does not get hot.when i first brought it home, it dried 2 loads, then no heat from there on.what parts might i need?:confused:
applianceman
#2 Posted : 16 years ago
applianceman
The heating element and the thermostats on the heater-can are the most likely parts that can cause this. This page may help Whirlpool Dryer No Heat Repair Guide
john437
#3 Posted : 16 years ago
john437
thanks for the tips,ill try this. hopefully they will be cheap to fix
