LSUStephen
#1 Posted : Sunday, July 16, 2017 1:25:43 PM(UTC)
LSUStephen
A couple of weeks ago I was getting a 4 flash error code. I ordered a new node shifter assembly, and installed it Tuesday night. We ran 4 loads Wednesday, and everything worked fine.
This morning we ran another load, and the the spin cycle did not run properly. The LED on the motor is blinking on and off in 1 second intervals. I tested the resistance on the mode shifter plug, and get about 70 Ohms. I tried the lid open and close reset method, and nothing changes. Any other tips to try to troubleshoot the problem?
LSUStephen
#2 Posted : Wednesday, July 19, 2017 5:33:29 AM(UTC)
LSUStephen
The problem seems to come and go. The spin cycle worked properly on 1 cycle yesterday, but not on others. It's as if the motor is not always getting the signal to run.
Guest (4)
