sup
#1 Posted : Thursday, July 13, 2017 9:44:31 AM(UTC)
sup
We have a coin operated Maytag LDG19CS (Series 02) dryer that is set to a 20 min timer cycle. It heats for the 1st 15 min and then cools for the last 5 min of the 1st cycle, and the clothes are not dry at the end. When we run a 2nd cycle, there is no heat.
What would be the likely causes of no heat on a second cycle?
Thanks,
Sup
brobriffin
#2 Posted : Tuesday, July 18, 2017 5:19:07 PM(UTC)
brobriffin
Man
United States
Sorry I don't have an answer however (no experience with coin op's)
you don't know how bad I just want to say add 50 cents....
Again sorry I just had to........................
Hoping this will put your thread back to the top and someone else may answer.
sup
#3 Posted : Wednesday, July 19, 2017 2:43:53 PM(UTC)
sup
I've confirmed that the gas ignites and provides heat during most of the 1st 20 minute timer cycle, but if we start a 2nd 20 minute cycle immediately, the igniter glows but there is no ignition and the igniter glow fades. If I wait a little while to start the 2nd cycle, it ignites and heats again. This dryer is probably about 20 yrs old. (P.S. Thanks for the bump brobriffin.)
brobriffin
#4 Posted : Wednesday, July 19, 2017 4:42:17 PM(UTC)
brobriffin
Man
United States
With that bit of info it sounds like the coils might be going bad..
Try this, set it to run and at about 8 to 10 minutes open the door or whatever to interrupt the cycle then in a few seconds or so shut the door and restart the cycle.
Does the gas ignite right away?
sup
#5 Posted : Wednesday, July 19, 2017 7:53:43 PM(UTC)
sup
I did that today at around 5 min into the 1st cycle and the gas did ignite.
