when large burner is on HI for an extended period of time it won't turn off when you select off. Sometimes if you wait long enough burner will eventually shut down otherwise you have to hit CB box in basement and wait a few minutes before trying to turn stove on again. From what I read and have inferred the relay on control PWB is stuck on or possibly a switch for burner is bad. I'm assuming switches are good or bad, not intermittently shorting out. A control pwb is about $150.00 so trying to figure out if this is the way to go or not. Any feedback is appreciated.
