Dave7777
#1 Posted : Sunday, July 9, 2017 4:34:29 AM(UTC)
Dave7777
Hi there,
I have a Whirlpool Duet washer that does not do anything after I press start. However, after about 5 minutes it starts to beep three times and flash the error code E1 F6.
To try to fix this, I cleaned the drainage pipe and also replaced the control board (WPW10491312) while checking all the connectors, however the problem is still the same.
Any help would be appreciated.
northshore
#2 Posted : Wednesday, August 2, 2017 6:08:43 PM(UTC)
northshore
We are having the same problem, is there a manual I can view to help trouble shoot? Do you know how to do a diagnostic test on this model?
johnmro
#3 Posted : Tuesday, May 1, 2018 8:52:11 AM(UTC)
johnmro
Dave, did you ever get your Duet Washer working? I am having similar issues. I have replaced the CCU (motther board) and Cleaned out the drain. I am lost...any ideas?
