Hi: I have a Maytag Bravos Washer that hums after the whole wash cycle is complete.
The machine goes through the entire cycle: sense, wash, rinse, spin. The "Clean" light goes off when it is finished but there is still a humming sound that will stop after about ten minutes. The humming sound seems to come from the mid/lower part of the washer
I unplug it so it doesn't keep running. When I plug it back in there is a gurgling sound coming from the drain pipe as if the machine is still trying to dump water out.
Then a couple of days later it was going through a constant fill/dump/fill/dump when I was trying to do a load of clothes. This problem however seems to come and go. Any ideas?
Thanks, -Jer
