ddart
#1 Posted : 17 years ago
ddart
Water is coming out of the water inlet system. ( There's is a drilled hole top right corner). It appears the water level switch is not working. How does this work.
Duane
kawfeeman
#2 Posted : 17 years ago
kawfeeman
when you say that water is coming out of the water inlet system , do you mean even when the d/w is not running ? or do you mean that water is coming out of the inlet valve ? winter time / cold weather can freeze water lines and crack inlet valves..
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 9 months ago
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 9 months ago
Dishwasher won't work. (Dishwasher Repair)
by Guest 10 months ago
High-pitched noise with LG dishwasher (Dishwasher Repair)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 10 months ago
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 11 months ago
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 11 months ago
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 12 months ago
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 12 months ago
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest about a year ago
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
