thime21
#1 Posted : Monday, June 26, 2017 12:10:39 PM(UTC)
thime21
I have a GSF26C4EXF02 Refrigerator with an in-door ice maker. The ice maker stopped working. While troubleshooting, I verifed water by using the icemaker test points V and L. However, it was not showing voltage between L and N and the motor test would not work either. I reset the optics by unplugging the fridge. Once plugged back in, the LED light was lit for 5 minutes and shut off when the infrared light was broken. I Replaced the ice maker and same problem exists. Any thoughts on what to check next would be appreciated.
Stacey Martinez
#2 Posted : Wednesday, June 28, 2017 9:33:05 PM(UTC)
Stacey Martinez
It has many reasons for ice maker stopped working. The first possibility that the water filter for the ice maker is clogged. If your vice maker doesn’t show the voltage that it might be my issue for the motor. So, please repair or replace it.https://icemakershub.com/
