muttineni
#1 Posted : Monday, June 26, 2017 10:20:49 AM(UTC)
muttineni
I have GE refrigerator model pscs3rgxcfss which is around 8 years old. Recently the refrigerator started behaving strangely. Few months ago the water started from the bottom and not dispensing water. Found out the water pipe broke near the valve and I replaced which after It worked fine till last week. Then last week the water stopped dispensing again. Also noticed that the temperatures in Freezer and cooler shot up to 25 and 54 respectively. the whole food in the freezer section thawed and ice turned into water leaking the whole floor. After power reset it was able to regain the cooling on both compartments but now the temperatures went into extremes again this time
- 14(freezer) and 5 (cooler). Now the ice dispenser and water dispenser doesn't work at all. And the temperature control has its own mind sometimes shutting off completely. I tried to replace the front panel assembly switch but it didn't work either.
Please advise on where the problem could be and what if sim one point me in the right direction
#2 Posted : Monday, June 26, 2017 11:35:12 AM(UTC)
Hello.
Sounds like the cause of these problems is the faulty main control board. It is located on the back of the refrigerator.
The main control board Part number: AP4363093
I believe the new control board comes with the installation instructions.
