Ok..so I haven't been able to find anything online to this specific problem. Bake, broil, nor self clean are heating up. When pressed, there is no error code but rather the digital screen flashes back to a blinking clock that is not the same time as the set clock....but it still keeps time for this reverted blinking clock. When pressed; The bake, broil, and self clean function will make a brief click sound before reverting back to the blinking clock. At the same time, the lock icon will blink twice during the single click. The door will not lock with the self clean option. Nothing is heating up for the oven. The stove top burners work fine. I don't think it's the igniters because, what are the chances that, both, igniters would go at the same time? Plus...there is this twice blinking lock icon. Any advice is much appreciated...especially if you've solved this same issue. Thank you
