BimmerFan
#1 Posted : Wednesday, June 14, 2017 3:58:06 PM(UTC)
BimmerFan
Hello,
I have the GE Profile with the ice maker, so when I press the ice maker button at the door when the "cube ice" settings selected, and I simulate the door close switch to see what happens , the solenoid in the ice maker goes up, but the augor motor will not turn. I took the assembly out, bought another motor, installed it, but same issue still remains.
I'm not sure how to check if there is power going into the motor , and if there is no power, what should I check next?
thanks!
BimmerFan
#2 Posted : Friday, June 16, 2017 6:43:04 AM(UTC)
BimmerFan
Do you guys have any idea on what to do here?
thanks
