Please help. If i run my dryer on anything but low or no heat it trips the breaker. I can start it right back up once flipping breaker, but I need to figure out asap. Not even a year old. Just started this tuesday night
Your model # is incorrect, if I make it make sense this is a pretty straight forward machine, get it off the model/serial tag inside the door. it'll be 110.xxxxxxxx If it's under 1 year call for service. If you attempt it yourself you may void warranty. I wouldn't usually do that unless the customer screwed something up badly and I felt future safety was an issue but it is the rule. If I guessed your model right it only has a single element so if it was shorted to ground usually any heat would trip breaker.
110.61262312, what if it has been over a year? I don't think it has, but in case. the heating element?
Please Help and thank you ahead of time
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
Give us the serial number and we can tell you how old it is.
That's an odd one. Quick question: If you select a high heat setting does it trip the breaker immediately when you start it? It's a fairly simple unit. Single element. No difference between high and low heat setting from an electrical standpoint. How old is your house it electrical panel?
It will run about 5-10 minutes. If the load is really full with like towels it kicks even in low heat to. I look up my receipt, it's exactly 1 year and 45 days.
I'm not sure the age of the breaker at all. I've had the house for 12 years and it's a converted old log cabin. the breaker the dryer is on runs very warm. It was a $800 dryer so I can't believe it's gone out already.
Here are pictures of breaker box, serial and dryer. Please help. File Attachment(s): Jonas76 attached the following image(s):
If your breaker is getting hot it probably needs to be changed just for safety. Heat means resistance and the breaker should have little to no internal resistance. They are easily changed if you are comfortable doing it. Otherwise call an electrician. Any internal short in the dryer should trip breaker as soon as it tries to power the element.
