I have a hotpoint nbxr333eg0ww that will start but only runs for about 5 mins then stops. i have already clean out the vent. any thoughts on what need to be replace?
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
How long after it stops does it take to restart? When you push the start button does the motor make a slight humming or buzzing sound before it starts? If the unit won't restart right away and or if you hear a buzzing / humming sound when starting the unit the motor is going bad. If so here is the part you need. GE WE17X10010 Dryer Motor Kit - AppliancePartsPros.com
