RPD15
#1 Posted : Monday, April 24, 2017 6:15:38 PM(UTC)
RPD15
My Frigidaire Affinity Dryer, FASE7370LW0, on startup, began to make what I believed to be a belt slipping sound. It would "Whir" for about 2 seconds, as if the belt was slipping, and then "catch" and work normally.
I changed out the belt, idler pulley and idler spring.
Now I get Whir/clunk and then the dryer works normally.
It only lasts seconds before it begins to function normally.
I rotated the drum manually and it sounds fine. Of course the torque that I can manually apply is nowhere near what the motor does.
Any ideas?
RPD15
#2 Posted : Tuesday, April 25, 2017 6:39:04 PM(UTC)
RPD15
Well, in listening more closely, it sounds like a drum roller.
I never would have guessed that.
I ordered one and when it comes in, I'll update this to let you all know if that was the problem.
