Mrlocksmith
#1 Posted : 8 years ago
Mrlocksmith
Hi:
I have a 1999 Kirkland/Whirlpool SAWB600HQO It makes a clicking sound on the startup of the Rinse Spin Cycle. This is a new sound and not one that was present before my repair. Other than that the machine works fine and sounds normal even on other spin cycles. The clock goes through the cycles and does not get stuck.
I just replaced the following due to Non - Agitation and a transmission that was very hard to turn by hand by putting vise grips on the motor shaft.
1) Clutch
2) Transmission
3) Motor Coupling
4) Motor and Cap
Here is short video of the sound and it goes away near the end as most of water is pumped out.
https://youtu.be/mSAUOqzQoH0
Any ideas where to look for the problem ?
Update: I just did a lighter load and there were no issues everything sounded and worked normally
Mark
