The door handle on the refrigerator half of my Whirlpool Gold Conquest fridge is loose. You can see the gap in the picture. There seems to be some type of connector between the door and the handle, and the connector is securely attached to the door. So somehow, the handle has come loose from the connector and I can't figure out how to get it back on. Any thoughts?
A model number may help others help you.
Many units use a clip. The handle can be removed by pushing up. The clip on the door or the handle may need adjusting or tightening. Be careful to not scratch the door. Not sure if this is used on your unit. |
THIS FORUM IS DEAD!!!!!!! |
What Is Under The Handle Help!!
Find the model number and then look up the handle parts on Appliance Parts Pros. It often has pictures of the parts. may even have a video on the part replacement. |
HELP PLEASE THANK YOU:eek:
