karinc1
#1 Posted : Monday, April 3, 2017 8:05:56 AM(UTC)
karinc1
I attempted to replace the control module but cannot remove the baler bar from the old module (at the end where it inserts into the control module). I watched the video ad it appears simple, but no matter what direction I pull, it won't budge. I tried to use the existing plastic insert piece with the new module, which fixed the ice-making problem, but now, it won't stop making ice. Doesn't seem to recognize that the baler is in up-mode. I think the problem can be solved if I can remove the baler and start over. Any ideas? Don't want to call for service since I've gotten this far already.
CitadelBlue
#2 Posted : Tuesday, April 4, 2017 7:45:03 AM(UTC)
CitadelBlue
take ice maker out .. a little WD40 perhaps?
karinc1
#3 Posted : Tuesday, April 4, 2017 12:36:49 PM(UTC)
karinc1
Eureka! The lube worked, just finished the job. ;) THanks again!!
CitadelBlue
#4 Posted : Tuesday, April 4, 2017 1:20:58 PM(UTC)
CitadelBlue
Guest (4)
