The motor went bad so i replaced it. Two weeks later the circuit board burnt up at the relay. Probably due to the motor pulling high amps. My question. is this dryer worth fixing? I found a circuit board for $110. And is there anything else that will likely go bad in the near future?Thanks
You've scrambled the model # I think. Is it actually MED9800TQ0? Are you getting F01 error on start up?
