I am in the process of replacing the water valve piece at the botom of my refrigerator due to damage. I requested a new valve, to find that the old valve unit that I have (Invensys - #240531101) has been discontinued. The new one that I received from Appliance Parts Pros is the replacement part model number (241734301). All was going well while replacing when I stumbled over the issue of the plastic water lines inside the refrigerator aren't fitting in the new unit. The old unit had a cap that attached these lines to the unit. The new unit looks as thought the lines need to slide in. Can you please let me know what I need to do to get this fixed? Am I missing something. Thanks!!
fgaughen
Cut the ends of your existing lines off smooth and insert them into the new valve.
Looks good so far......I will let you know how it turns out.....thanks for the quick response.
Outstanding......works great!!
Thanks for the help!
