Twang
#1 Posted : Friday, March 10, 2017 8:22:32 AM(UTC)
Twang
My Maytag Bravos washer sounds like a airplane taking off in the spin cycle. From the internet research I have done, it appears I need to replace the tub seal and bearing. The seal and bearing kit is around $70 on the internet. The tool for setting the bearing is a "Bearing Driver Tool" part number W10447783 for $115. That's a lot of money for a one-time use. How difficult is it to install the bearing without the tool? Can you give me some hints on how to do it? Thanks for your help.
PNWDrew
#2 Posted : Sunday, March 12, 2017 6:30:44 PM(UTC)
PNWDrew
You will not easily install that kit without the tool. It is probably possible with some threaded rod and a bunch of nuts and washers from home depot but it you don't get them aligned you'll be doing it again in a few months.
I'm sure you can find some video of how to do it without the tool, but you'd be better off trying to beg or borrow it from a shop or another poor soul whose done it already.
For reference my employer charges about $300 for the whole job.
Twang
#3 Posted : Monday, March 13, 2017 3:28:21 AM(UTC)
Twang
Thank you for the advice. Good to know what to expect. I guess I should look around for a place to rent the tool.
