ti_chris
#1 Posted : Sunday, March 12, 2017 11:02:27 AM(UTC)
ti_chris
I've read a couple of posts here to suspect what's wrong, but wanted to confirm. My washer is currently having a hard time rotating. I have run the diagnostic and have observed that it does fine with the first test (tumble clockwise). However it fails the low & high spin. There, the LED reads numbers that quickly change anywhere from 30 to 150. I suspect that it's the rotor assembly & sensor switch, but would love to confirm my suspicion first.
jimctec
#2 Posted : Thursday, March 16, 2017 9:06:20 AM(UTC)
jimctec
Is there any noise in spin? Any wiggle in the basket its self compared to the outer tub. You need to know if the bearings are good. Does the motor action sound abnormal in spin? Sometimes is louder or pulsing sound... The least expensive part to try would be the Hall sensor that picks up motor speed and sends signal to control. You have to remove the rotor and stator to get to it. P#6501KW2002A.
ti_chris
#3 Posted : Thursday, March 16, 2017 1:05:42 PM(UTC)
ti_chris
Things seem normal when testing #1. For #2 however, it does pulse and it grinds to a halt if there's a significant load in there. I'll try and grab a video tonight to illustrate what I'm seeing. Would that be more of an indication that the bearing is toasted?
ti_chris
#4 Posted : Thursday, March 16, 2017 8:15:30 PM(UTC)
ti_chris
Here's the video of what it does:
https://youtu.be/HCfEZlV3pT4
