rgarris1969
#1 Posted : Saturday, March 11, 2017 6:59:15 PM(UTC)
rgarris1969
Dryer was heating when it wanted. I replaced heating element, thermostat, thermal fuse, and hi-temp cut out. Now no heat at all and noticed dryer will not spin on NO HEAT cycle. Any ideas on what I need to look into?
ThatGuy
#2 Posted : Saturday, March 11, 2017 9:09:14 PM(UTC)
ThatGuy
Groups: Expert
United States
I would guess its the timer. Most of the problems you described can be caused by a timer with burnt contacts inside.
If you can find the wiring diagram, you can check it with a multi-meter.
Whirlpool W10894766 Timer - AppliancePartsPros.com
