psk
#1 Posted : Monday, March 6, 2017 8:46:57 AM(UTC)
psk
Hello, I need help with wiring the downdraft fan switch. This switch is for C221 Jenn-Air electric cook-top that has two wires for the downdraft fan. The fan was working before I tried to replace one of the infinite switches below the fan switch. I must have accidentally touched one of the fan wires while replacing the infinite switch. The wire which is attached to the left terminal of the fan switch is hanging in the air and I do not know where it should be connected to. The other wire (Black) which is attached to the center/right terminal is still connected to the motor below. The disconnected wire has a hook at the end of the crimp and I feel that it can be piggy bagged onto some other wire, but I just do not know which one. Could someone help, please?
psk
#2 Posted : Wednesday, March 8, 2017 10:20:34 AM(UTC)
psk
I found that the disconnected wire needs to be connected/piggy bagged onto one of the wires of the infinite switch. Once it was connected, the fan worked.
Guest (4)
