the beeper volume adjustment controls stopped working, the sound level is stuck at Low...will replacing the speaker resolve this issue?
Groups: Expert
Originally Posted by: hls  the beeper volume adjustment controls stopped working, the sound level is stuck at Low...will replacing the speaker resolve this issue? Its possible. I would think the electronic control would be more likely to be the problem. Both parts are pretty expensive. http://www.appliancepartspros.c...for-ge-jvm1660wb001.html
