Howard67
#1 Posted : Thursday, February 23, 2017 9:20:15 AM(UTC)
Howard67
My machine runs through all cycles except the final drain, then shuts off. When I turn the dial back it drains. There is also a strange odor at about that time.
brobriffin
#2 Posted : Tuesday, March 7, 2017 4:27:26 AM(UTC)
brobriffin
Man
United States
Can you explain the smell?
Is it like a burning electrical odor?
Does the smell originate from the control panel area or from the bottom of the machine?
A few possibilities:
1. Timer
2. Wiring short from timer to drain pump
3. Drain pump
1. GE WH49X10088 Cntrl & Shield Kit - AppliancePartsPros.com
3. GE WH23X10030 Pump - AppliancePartsPros.com
washing machine not draining properly (Washer Repair)
by htuttle 5/30/2009 8:53:36 AM(UTC)
